I have one axis which only moves in one direction
sometimes.
E.G. I can move south (positive
y) but when I try to move north the soft limit disables
the axis where it sits. This happens while the axis
position reports as being within the valid soft limits
range. I.E. Max is 180k, min is -1k I'm at 60k I would
expect to be able to move in either direction.
Does anyone see any problems
with the code below?
The problem is with axis 1. It
doesn't happen every time.
Second question, I was
expecting kflop to stop movement when there is an issue
with following error. That doesn't happen.
Do I need to be in closed loop
step direction for that?
If I put it in closed loop
step direction and zero out pid coefficients will that do
it without actually making changes to the axis positions?
The drives have there own PID
control, and I don't really trust their encoder outputs.
Colin
#define TMP 10
#define CNTS_PER_INCH_X
#define CNTS_PER_INCH_Y
#define CNTS_PER_INCH_Z
#define X 0
#define Y 1
#define Z 2
#define MaxY 180000
#define MinY -1000
#define MaxZ 1000
#define MinZ -80000
#define MaxX 295000
#define MinX -1000
#define ESTOP_BIT 139
#define ZLIM_BIT 139
#define XLIM_BIT 138
#define YLIM_BIT 137
double DROx, DROy, DROz, DROa, DROb, DROc;
void SetSoftLim(int);
void home(void);
void center(void);
void estop(void);
void spindleWDog(void);
void SetZ(void);
void AxisEnable(void);
int enable=1;
int SLST=1;
if (ch2->Enable) DisableAxis(Z); // axis
still enabled? - Disable it
if (ch1->Enable) DisableAxis(Y); // axis
if (ch0->Enable) DisableAxis(X); // axis
ClearBit(152);
ClearBit(154);
ClearBit(153);
ClearBit(155);
DefineCoordSystem(X,Y,Z,-1);
FPGA(STEP_PULSE_LENGTH_ADD)=30 + 0x40 ;
ch0->InputMode=ENCODER_MODE;
ch0->Vel=87500;
ch0->Accel=300000;
ch0->Jerk= 4000000;
ch0->P=0;
ch0->I=0;
ch0->D=0;
ch0->FFAccel=0.0001;
ch0->FFVel=0.003;
ch0->MaxI=200;
ch0->MaxErr=12;
ch0->MaxOutput=2000;
ch0->DeadBandGain=0;
ch0->DeadBandRange=20;
ch0->InputChan0=4;
ch0->InputChan1=0;
ch0->OutputChan0=20;
ch0->OutputChan1=0;
ch0->MasterAxis=-1;
ch0->LimitSwitchOptions=0x11f;
ch0->LimitSwitchNegBit=138;
ch0->LimitSwitchPosBit=139;
ch0->SoftLimitPos=MaxX;
ch0->SoftLimitNeg=MinX;
ch0->InputGain0=-1;
ch0->InputGain1=1;
ch0->InputOffset0=0;
ch0->InputOffset1=0;
ch0->OutputGain=-1;
ch0->OutputOffset=0;
ch0->SlaveGain=1;
ch0->BacklashAmount=0;
ch0->BacklashRate=0;
ch0->invDistPerCycle=0;
ch0->Lead=0;
ch0->MaxFollowingError=12;
ch0->StepperAmplitude=20;
ch0->iir[0].B0=1;
ch0->iir[0].B1=0;
ch0->iir[0].B2=0;
ch0->iir[0].A1=0;
ch0->iir[0].A2=0;
ch0->iir[1].B0=1;
ch0->iir[1].B1=0;
ch0->iir[1].B2=0;
ch0->iir[1].A1=0;
ch0->iir[1].A2=0;
ch0->iir[2].B0=0.000768788;
ch0->iir[2].B1=0.00153758;
ch0->iir[2].B2=0.000768788;
ch0->iir[2].A1=1.92076;
ch0->iir[2].A2=-0.923833;
ch1->InputMode=ENCODER_MODE;
//ch1->InputMode=NO_INPUT_MODE;
ch1->Vel=87500;
ch1->Accel=300000;
ch1->Jerk= 4000000;
ch1->P=0;
ch1->I=0;
ch1->D=0;
ch1->FFAccel=0.0001;
ch1->FFVel=0.003;
ch1->MaxI=200;
ch1->MaxErr=12;
ch1->MaxOutput=2000;
ch1->DeadBandGain=0;
ch1->DeadBandRange=20;
ch1->InputChan0=1;
ch1->InputChan1=0;
ch1->OutputChan0=21;
ch1->OutputChan1=0;
ch1->MasterAxis=-1;
ch1->LimitSwitchOptions=0x11f;
ch1->LimitSwitchNegBit=136;
ch1->LimitSwitchPosBit=137;
ch1->SoftLimitPos=MaxY;
ch1->SoftLimitNeg=MinY;
ch1->InputGain0=-.5;
ch1->InputGain1=1;
ch1->InputOffset0=0;
ch1->InputOffset1=0;
ch1->OutputGain=-1;
ch1->OutputOffset=0;
ch1->SlaveGain=1;
ch1->BacklashAmount=0;
ch1->BacklashRate=0;
ch1->invDistPerCycle=0;
ch1->Lead=0;
ch1->MaxFollowingError=24;
ch1->StepperAmplitude=20;
ch1->iir[0].B0=1;
ch1->iir[0].B1=0;
ch1->iir[0].B2=0;
ch1->iir[0].A1=0;
ch1->iir[0].A2=0;
ch1->iir[1].B0=1;
ch1->iir[1].B1=0;
ch1->iir[1].B2=0;
ch1->iir[1].A1=0;
ch1->iir[1].A2=0;
ch1->iir[2].B0=0.000769;
ch1->iir[2].B1=0.001538;
ch1->iir[2].B2=0.000769;
ch1->iir[2].A1=1.92081;
ch1->iir[2].A2=-0.923885;
ch2->InputMode=ENCODER_MODE;
ch2->Vel=50000;
ch2->Accel=200000;
ch2->Jerk=3000000;
ch2->P=0;
ch2->I=0;
ch2->D=0;
ch2->FFAccel=0.001;
ch2->FFVel=0.003;
ch2->MaxI=200;
ch2->MaxErr=24;
ch2->MaxOutput=2000;
ch2->DeadBandGain=0;
ch2->DeadBandRange=20;
ch2->InputChan0=2;
ch2->InputChan1=0;
ch2->OutputChan0=19;
ch2->OutputChan1=0;
ch2->MasterAxis=-1;
ch2->LimitSwitchOptions=0x11f;
ch2->LimitSwitchNegBit=139;
ch2->LimitSwitchPosBit=0;
ch2->SoftLimitPos=MaxZ;
ch2->SoftLimitNeg=MinZ;
ch2->InputGain0=.5;
ch2->InputGain1=1;
ch2->InputOffset0=0;
ch2->InputOffset1=0;
ch2->OutputGain=1;
ch2->OutputOffset=0;
ch2->SlaveGain=1;
ch2->BacklashAmount=0;
ch2->BacklashRate=0;
ch2->invDistPerCycle=0;
ch2->Lead=0;
ch2->MaxFollowingError=12;
ch2->StepperAmplitude=20;
ch2->iir[0].B0=1;
ch2->iir[0].B1=0;
ch2->iir[0].B2=0;
ch2->iir[0].A1=0;
ch2->iir[0].A2=0;
ch2->iir[1].B0=1;
ch2->iir[1].B1=0;
ch2->iir[1].B2=0;
ch2->iir[1].A1=0;
ch2->iir[1].A2=0;
ch2->iir[2].B0=0.056495;
ch2->iir[2].B1=0.112989;
ch2->iir[2].B2=0.056495;
ch2->iir[2].A1=1.22565;
ch2->iir[2].A2=-0.451634;
if(ESTOP_BIT && ZLIM_BIT &&
XLIM_BIT && YLIM_BIT )
EnableAxisDest(Y,0); //y
EnableAxisDest(X,0); //z
EnableAxisDest(Z,0); //x
// SetBit(154);
// SetBit(152);
// SetBit(153);
while(1){
/*if(ReadBit(48)) { //soft limits disable and
manual home sequence
ClearStopImmediately();
SetSoftLim(0); //disable soft limits
ClearBit(48);
while(~ReadBit(48)){
home();
WaitNextTimeSlice();
ClearBit(48);
SetSoftLim(1);
//home();
//center();
estop();
if(CheckDoneXYZABC()==0) SetBit(155);
else ClearBit(155);
//spindleWDog();
//SetZ();
void estop(void){
if (!ReadBit(ESTOP_BIT) || !ReadBit(ZLIM_BIT) ||
!ReadBit(YLIM_BIT) || !ReadBit(XLIM_BIT))
ClearBit(152);
ClearBit(154);
ClearBit(153);
ClearBit(155);
else if(ReadBit(55) && !enable){
enable=1;
EnableAxisDest(Z,ch2->Dest); //Z
EnableAxisDest(Y,ch1->Dest); //Y
EnableAxisDest(X,ch0->Dest); //X
SetBit(152);
SetBit(154);
SetBit(153);
SetBit(155);
ClearBit(55);
else if(ReadBit(55) && enable){
enable=0;
ClearBit(152);
ClearBit(154);
ClearBit(153);
ClearBit(155);
ClearBit(55);
void SetSoftLim(void){
if(SLST) {
else{
ch0->SoftLimitPos= 80000;
ch0->SoftLimitNeg=-80000;
ch1->SoftLimitPos=80000;
ch1->SoftLimitNeg=-80000;
ch2->SoftLimitPos=80000;
ch2->SoftLimitNeg=-80000;
void SetZ(void){
if(ReadBit(53)) {
ch2->SoftLimitNeg=ch2->Dest;
ClearBit(53);
if(ReadBit(54)) {
ClearBit(54);
void home (void){
if(ReadBit(49)){ //home sequence X,Y
ClearBit(49);
if(ReadBit(52)){ //home sequence Z
ClearBit(52);
void center(void){
if(ReadBit(50)){ //center x
GetDROs(&DROx, &DROy, &DROz,
&DROa, &DROb, &DROc);
DoPCFloat(PC_COMM_SET_X, DROx/2);
ClearBit(50);
if(ReadBit(51)){ //center y
DoPCFloat(PC_COMM_SET_Y, DROy/2);
ClearBit(51);
ClearBit(48); // soft limits
ClearBit(49); // home x and y
ClearBit(50); // center x
ClearBit(51); // center y
ClearBit(52); // home z
persist.UserData[10] = 0; //set current tool to zero
force tool change on first M6
// EnableAxisDest(Z,ch2->Dest); //Z
// EnableAxisDest(Y,ch1->Dest); //Y
// EnableAxisDest(X,ch0->Dest); //X
int lasty = ch1->Dest;
int lastx = ch0->Dest;
int lastz = ch2->Dest;
while(1){
ClearBit(48);
home();
ClearBit(48);
SetSoftLim(1);
home();
center();
//estop();
//spindleWDog();
SetZ();
void estop(void){
SetBit(144);
SetBit(145);
else {
ClearBit(144);
ClearBit(145);
void spindleWDog(void){
if(ADC(0) <= 1500){ //overload condition met
StopCoordinatedMotion();
SetBit(145);
SetBit(144);
void MoveX(double v); // define sub functions
void MoveY(double v);
void MoveZ(double v);
Move(X,v * CNTS_PER_INCH_X);
while (!CheckDone(X));
Move(Y,v * CNTS_PER_INCH_Y);
while (!CheckDone(Y));
Move(Z,v * CNTS_PER_INCH_Z);
while (!CheckDone(Z));
// ch2->SoftLimitPos= 80000; //y
// ch2->SoftLimitNeg=-80000; //y
// ch1->SoftLimitPos=80000; //z
// ch1->SoftLimitNeg=-80000; //z
// ch0->SoftLimitPos=80000; //x
// ch0->SoftLimitNeg=-80000; //x
// EnableAxisDest(0,0);
// EnableAxisDest(1,0);
// EnableAxisDest(2,0);
